Here is the data tag, which shows serial number and delivery date.
David Doyle can probably tell a lot from these numbers. If the 0018 means that it's number 18, it could explain at least three oddities found so far, apparently only one fuel tank was used and the battery tray was never occupied. Long battery cables are connected directly to the starter and they are long enough to keep the batteries on the platform behind the cab...doesn't look like a civi fab job. The cables that would normally go from the bulkhead conectors to the battery box are different from what the manuals show. The third oddity is the lack of black-out driving light, there is not even a space for it.
Maddawg, the axles are Rockwell 6.40:1.
