- 10,350
- 75
- 48
- Meadows of Dan, Virginia
The 1792XD filter, which I received and also pictured above occupies a total space of 17-1/5 x 9 x 6 inches including the mounting bracket and brass fittings. The canister alone is 12 x 5-3/8 inches. The flow rate is different also, about 20-22 gpm. Pressure drop varies according flow rate.
Like I mentioned in the post above, I'll remove the heater for the test.
I think there may be other considerations for changing oil more frequently also, like water and acid formation in the oil. A visual will not indicate the need for changing oil IMHO. Also how many hours do we use these trucks/year, 100, it's not like we run them like the big rigs? How many starts/year, 50?
Spoke with a UPS driver the other day and he said that they are required to shut down the engine for every stop they make. He did about 40 deliveries/pick-up that day and the oil pressure took about 3-5 seconds to build up when we checked it. He had over 500,000 miles on his truck engine without any major engine related problems....
