Yes Im Posting ANOTHER Filter Thread!!
cranetruck
77
Meadows of Dan, Virginia
Did finish the plumbing, but I'm not comfy with the straight threads in the drilled out cap screws (noted in image). I'm trusting the teflon tape to keep it from leaking, not a good long term solution, although yellow tape is used.
The 3/4 inch plumbing is a bear to work with.
cranetruck
77
It runs!
First time to oil pressure (to fill new filter and lines): 15 seconds
After shut down and restart, the oil pressure was up in less than 3 seconds.
Pressure drop across new oil filter after 1/2 hr at idle: 6 psi @ 154°F (thermocouple in coolant plug, should be the same as oil temp more or less)
I used a paste to seal some pipe joints for the first time and 3 out of 5 leaked. :(
The taped joints held up fine as usual. Another project to fix the leaks. aua
1,813
Bjorn brings up an interesting point with the tape vs paste. My rule of thumb is to use tape ( I only use yellow gas tape) on everything but PVC and CPVC. My thought is the fact that CPVC and especially PVC can crack if you crank it too much. The yellow tape I use may not work well on smaller stuff such as 1/8NPT.
OSO
Arlington,Wa
I like this test ! Best way to get the right data, and not to mention a real craftsman at work . The color match was fantastic! Real pro on the spray bomb. I used to paint a motorcycle tank for a friend back in the 70's, using auto paint put into spray bombs, I would wet sand ,then buff paint out. Anyway NICE WORK!!! [thumbzup] OSO
OPCOM
27
Dallas, Texas
If the kit has straight threads in the drilled out cap screws, how about if pipe nipples were put in and welded in thecap screws so they would not ever leak, and then you would have a tapered thread on top. Does this sound reasonable?
OPCOM
27
Dallas, Texas
Bjorn, that's not an error being fixed, it's a "design spin". At least that's what I have learned since I went from engineering to marketing!!
Djfreema, Dang I was going to say that also! What do we suppose the reason for that unneccessarily huge box was?
mangus580
282
Western NY
Agreed Patrick. The Bolts that were made for the kit, were made for a different type of fitting than Bjorn used. Bjorns fittings didnt fit right because he put a spin on the design by using different hoses and such.
bottleworks
Central NC
Good question... I put an A/C evaporator in mine...Still need to make the hoses to use it...
Cranetruck, at some point, would you be willing to move your oil filter below the oil cooler to see if your higher "time until pressure" numbers go down relative to the position of the oil filter?
1,813
Bjorn, have you been running the truck with any frequency? I'm curious to see if the filter makes a visible difference in the oil after the filter change.
