AMX70
- 0
- 0
- Warrenton, Va
I finally took the plunge and bought the new ECU for the Eaton autoshift transmission. Sure is a interesting truck to drive. Never drove a cab forward vehicle before this one.
Anyway I have a few questions about the basic 5 ton trucks.Mine is based on a G744 series platform from what I can tell. But has the engine mid mounted and the cab in front.
What do most 5 ton trucks weigh and what is the weight distribution on a tractor? Mine was 17600 lbs on the front axel and 33600 lbs total. Seems high on the front.
I assume its GVW is 62K, so what do most 5 ton tractors register there trucks at? Basically I want to pull a 20 ton trailer. So assume I need to register it at 102K
It has 12 x20.00 tires on all corners. I thought most 5 tons had 14x 20.00?
My biggest issue is that it is not over 25 years old and needs registered as a normal over the road truck, but for private use. So state taxes are going to be killer. (They are based on the GVW)
Thanks for any help
Thanks for any help
