Blackmagic94
- 14
- 18
- Oro Valley/AZ
pics of wood ramps?
Can't get pics for a day or two. I'm loaded for Dirtbag and the ramps are tucked under the quads. I'll try to remember to get a pic of them in action and upload when we return.pics of wood ramps?
Try the diagram with a second set of ramps, to ease the approach angle. Material choice and construction still needs to be carefully considered.I was just playing with sketchup, and came up with this. Now that I've seen it, I know I was kidding myself. This is different than what I was thinking, but it might give someone an Idea!
Yeah I'm going to play around with it. I will add some more stuff tomorrow, as for now, its bedtime!Try the diagram with a second set of ramps, to ease the approach angle. Material choice and construction still needs to be carefully considered.
Rat, here's something that might work. put two 2x4's on edge under the 2x12's on either edge. Use good quality adhesive and 1/4"x4" lag screws about every 1 1/2'. In the center, put a 4x4 leg with wood spacers to take up the space between the outer 2x4's. Round the end of the 4x4 so it can swivel as a fold out leg. get a 1/2" bolt long enough to go the entire width of the board. Attach a good size chain to an eye bolt in the other end of the 4x4 and attach the other end of the chain to a bolt toward the bottom of the ramp. This will keep the leg from kicking out, and will help divide the ramp into 6' sections. 'Course I'm just pulling this out of my arse, but maybe it will work for you. I'd also mix in some sand into some paint, to paint the top for traction.I was just playing with sketchup, and came up with this. Now that I've seen it, I know I was kidding myself. This is different than what I was thinking, but it might give someone an Idea!
You may want another leg at the top. As it's drawn now you are still putting a lot of weight on a small section of material where it sits on the tail gate. A second leg would reduce much of that stress.Ok I like this one better. I can add more legs if I want too. looks heavy but looks strong also!
Yeah I was thinking a leg at top and possibly one between the middle leg and the top. Basically make this a self standing rampYou may want another leg at the top. As it's drawn now you are still putting a lot of weight on a small section of material where it sits on the tail gate. A second leg would reduce much of that stress.
Yeah, that's what I was thinking of! If it works, I've got a patent on it.Oh scratch that, I read your post wrong, let me redo this.
Ultimatly i intend to solve this issue with a knuckle-boom crane and lifting points permanantly mounted on my Jeep, for the meantime I have attacked the problem from a middleground. 12 foot long ramps are more than I want to deal with. I have a pair of 6 foot ramps that started life as a 12' aluminum loading ramp for a commercial moving truck. They have afforded me plenty of opportunities to load/unload at locations that would prove worthless without any form of ramps. Granted you still have to find a bit of a hill, but all you must find is a small hill that is enough to bridge the gap. Almost any ditch alongside forest roads will work. Ironically enough, so do the "tank traps" that are generally dug at the end of roads that have been closed.After reading this I'm intrigued...I want to make some ramps to load my jeep into the back of my truck, and do it fairly cheaply and easily...I'm still not sure if the jeep will fit, but I'll measure it tomorrow. Anyway..saying it does fit, the curb weight of the jeep is 4340lbs. I want to make 12' ramps that one man can handle. Will 2x12's braced with a 2x4 placed vertically along the length under the 2x12's handle that weight? I've never really messed with lumber much, so don't beat me if that's a crazy idea!
Not a bad design; going to 1 1/2 " angle will add a considerable amount of stiffness. 2", even more.I did a little ramp workup myself granted it is not as nice. I am planning on 1"x1"x1/4" angle iron for the ramp material. They should be about 20' long and fold in half. Still have not worked out the support yet. I really wanted longer ramps because the 10' long one made from double 2"x10"x10' are really steep and make me nervous when loading or unloading my big 6x6 atv.
