full shut off solenoid on NHC250?
73m819
325
gainesville, ga.
You buy the Cummins one, you pay $55, I paid about $20 for mine, any big truck parts house has them, the one I brought is a BEPCO p/n 6997324, 24v fuel solenoid
Hooty481
Russell County Kentucky
my m818 wouldn't shut off because the little metal disk with the o-ring built in had a groove in it from where it had set and not been run. i just put in a new one and it shut off fine right now.
73m819
325
gainesville, ga.
Put a SPRING on the EMG. engine kill, that way you don't have to go to the motor to RESET it each time and you can do the shut down like a multi. even with a new solenoid put the spring on in case it takes a dump later, just screw the screw in and go, also this way you can run WITHOUT batteries if need be to get you home or out of a SHTF mess
This was NOT my idea, you can thank Will Wagner
5tondeuce
Hampton/New Brunswick/Canada
Would you believe the guy that owned the 813 before me removed the EMG shut off totally, not sure why he would do this
73m819
325
gainesville, ga.
leaked, to lazy to fix it, you NEED to put it back, any good sealing on/off valve will work. You have NO WAY to shut the engine down if the shut off solenoid STICKS open other then a stall and that is bad for everything and yes I have had them stick open before.
EMD567
Driver for the Ga Mafia
47
Aiken SC
They also won't shut off if the control box has a relay that is hanging up. Ferro's 818 has one that doesn't shut the engine of right away- sometimes it takes 20-30 seconds to shut down. The one on my 814 kills the engine right away, just as god and cummins designed it.
5tondeuce
Yup I agree with you Ron, the cable is still there just the valve missing. I my see if I can get a factory one. I just like original stuff.
EMD567
47
Aiken SC
Is that the black box on the fire wall?
Yes. They have two types- the old one that came on the 809's, and the new ones which came on the 900 series. THe old one are very easy to rebuild(think like the doghead mod). I have been told that the new ones have potted parts, and are harder to repair. I have seen the inside of old one- it's just heavy duty relays and some wiring.
Ferro has the new style on his 818, I have the old style on my 814. Mine is as installed by AMG, as my 814 has not gone thru a depot rebuild. And yes, Ferro and I are stocking up on 5 ton parts.
73m819
325
gainesville, ga.
You can use a 900 5t box on a 809 BUT NOT a 809 box on a 900 5t
I really do not see why someone can not get rid of the 809 box all together, just have a main on/off solenoid, then wire there to each system, I have run a lot of cranes with the 855s ALL are wired this way, VERY KISS
5tondeuce
Yes. They have two types- the old one that came on the 809's, and the new ones which came on the 900 series. THe old one are very easy to rebuild(think like the doghead mod. I have been told that the new ones have potted parts, and are harder to repair. I have seen the inside of old one- it's just heavy duty relays and some wiring.
Cool, I need to dig into this stuff and learn more about it, I've been too busy collecting trucks and have not had a lot of time to work on them. This is a great place to learn though. Thanks
EMD567
47
Aiken SC
Go thru your 5 tons, and compare the boxes. I'll bet you have at least one of each kind
EMD567
47
Aiken SC
That I don't know-I have never compared the two side by side. I think mine is all metal, but I am drawing a blank right now. I will go out and look tomorrow.
73m819
325
gainesville, ga.
So if the relay in the box is stuck open I guess you will not have 24v going to the shut off solenoid?
Yes, also if for some reason the oil pressure sender is messed up the the box thinks there is oil pressure (engine running) and then no starter, this is why you can't restart while rolling unless you step on the clutch
