- 12,195
- 327
- 0
- gainesville, ga.
You buy the Cummins one, you pay $55, I paid about $20 for mine, any big truck parts house has them, the one I brought is a BEPCO p/n 6997324, 24v fuel solenoid
Its funny my M813 wont start and my M818 wont shut off, same problem you have. I guess either way it is the solenoidok. just wondering the other day my truck would not shut off. thought that might have been the problem.
Would you believe the guy that owned the 813 before me removed the EMG shut off totally, not sure why he would do thisPut a SPRING on the EMG. engine kill, that way you don't have to go to the motor to RESET it each time and you can do the shut down like a multi. even with a new solenoid put the spring on in case it takes a dump later, just screw the screw in and go, also this way you can run WITHOUT batteries if need be to get you home or out of a SHTF mess
This was NOT my idea, you can thank Will Wagner
This is great info but I'm not quite sure which metal disk you mean? I havent had one of the pumps apart yetmy m818 wouldn't shut off because the little metal disk with the o-ring built in had a groove in it from where it had set and not been run. i just put in a new one and it shut off fine right now.
leaked, to lazy to fix it, you NEED to put it back, any good sealing on/off valve will work. You have NO WAY to shut the engine down if the shut off solenoid STICKS open other then a stall and that is bad for everything and yes I have had them stick open before.Would you believe the guy that owned the 813 before me removed the EMG shut off totally, not sure why he would do this
Outstanding idea!Put a SPRING on the EMG. engine kill, that way you don't have to go to the motor to RESET it each time and you can do the shut down like a multi.
Yup I agree with you Ron, the cable is still there just the valve missing. I my see if I can get a factory one. I just like original stuff.leaked, to lazy to fix it, you NEED to put it back, any good sealing on/off valve will work. You have NO WAY to shut the engine down if the shut off solenoid STICKS open other then a stall and that is bad for everything and yes I have had them stick open before.
Is that the black box on the fire wall?They also won't shut off if the control box has a relay that is hanging up. Ferro's 818 has one that doesn't shut the engine of right away- sometimes it takes 20-30 seconds to shut down. The one on my 814 kills the engine right away, just as god and cummins designed it.
Yes. They have two types- the old one that came on the 809's, and the new ones which came on the 900 series. THe old one are very easy to rebuild(think like the doghead mod). I have been told that the new ones have potted parts, and are harder to repair. I have seen the inside of old one- it's just heavy duty relays and some wiring.Is that the black box on the fire wall?
Cool, I need to dig into this stuff and learn more about it, I've been too busy collecting trucks and have not had a lot of time to work on them. This is a great place to learn though. ThanksYes. They have two types- the old one that came on the 809's, and the new ones which came on the 900 series. THe old one are very easy to rebuild(think like the doghead mod. I have been told that the new ones have potted parts, and are harder to repair. I have seen the inside of old one- it's just heavy duty relays and some wiring.
Do the new style ones look like the old ones from the outside or are they different>Go thru your 5 tons, and compare the boxes. I'll bet you have at least one of each kind
So if the relay in the box is stuck open I guess you will not have 24v going to the shut off solenoid?Go thru your 5 tons, and compare the boxes. I'll bet you have at least one of each kind
Yes, also if for some reason the oil pressure sender is messed up the the box thinks there is oil pressure (engine running) and then no starter, this is why you can't restart while rolling unless you step on the clutchSo if the relay in the box is stuck open I guess you will not have 24v going to the shut off solenoid?
