quickfarms
- 24
- 38
- Orange Junction, CA
Lots of good info
I suggest plain old undercoating under your fenders and bed. It is removable if you need to work on it, and it can be touched up. It is also quite flexible, which is probably a good thing in areas that can get hit by pebbles as you motor along.I have read all of this and never even holding a paint sprayer before, I'm overwhelmed. Some questions please. I have a M923A1 I would like to paint it with a Marine paint scheme. Where do I find patterns to go by. I see everyone keeps talking about 24087 is that a single color and then how do I find the other colors and codes. I want to paint the bottom of the bed and wheel wells with herculiner, then the rest of the truck in full Marine design.
I also have a friend from racing who is around the Charlotte area and does sand blasting. I had my chassis blasted and he does a great job. If interested let me know. All help on the paint will be helpful. Just explain like I know nothing, because I don't. Thank you Mark
How do you mean removable?I suggest plain old undercoating under your fenders and bed. It is removable if you need to work on it, and it can be touched up. It is also quite flexible, which is probably a good thing in areas that can get hit by pebbles as you motor along.
He probably means it can be sanded off without blasting/dipping.How do you mean removable?
I had also been thinking of Herculiner for the underside of my truck, so I am very curious![]()
As Yolner already commented, you can remove it by scraping, with a little heat from a hot air gun and a putty knife, with solvent, or even just muscle the fasteners off past it. Herc and the other bed coatings don't play nice like that. POU (plain 'ol undercoating) is also a lot less expensive, easier to install and not picky about surface prep. Lastly, POU is soft and withstands a hit by a rock. Bedliner is not really designed for that type of impact, so perhaps it will chip over time.How do you mean removable?
Most of your post makes lots of sense, but there were 2 places that are not constant with my personal Herc experience.As Yolner already commented, you can remove it by scraping, with a little heat from a hot air gun and a putty knife, with solvent, or even just muscle the fasteners off past it. Herc and the other bed coatings don't play nice like that. POU (plain 'ol undercoating) is also a lot less expensive, easier to install and not picky about surface prep. Lastly, POU is soft and withstands a hit by a rock. Bedliner is not really designed for that type of impact, so perhaps it will chip over time.
That's good to know about Herc. Of course, it can only hold on for as good as whatever it is applied on top of. If the underneath paint flakes off, the Herc will come with it. That's the beauty of POU, just spray on a bit more and it patches perfectly. Plus, because it remains pliable, it kind of bridges what it needs to bridge.Most of your post makes lots of sense, but there were 2 places that are not constant with my personal Herc experience.
When I built a jeep bumper and Herced it, that stuff didnt give a crap about surface prep, it stuck VERY well, and I have a difficult time picturing it chipping.
That being said, I have not ever used POU for anything, and cheap is good! I will have to research this more online before I decide one way or the other. Not saying your post is wrong, because what do I know? I just wanted to share my experiences.![]()
going to try this on a tool box thie weekend!!!here is mike/wsucougarsx formula for 383 carc
home depot - base = behr premium plus exterior flat, matte deep base #4300
colorant............. Oz... 384th
ax-perm yellow... 2....... 68
d-thalo green..... 1...... 16
kx-white............. 0...... 112
l-raw umber...... 8....... 80
the above formula is from a previous thread. It's the color that i purchased.
I used a inexpensive spray gun from harbor freight.
Karl
Nope it's semi gloss 24087 OD, the Marines I think at that time used semi gloss 24052 OD or lusterless 35042 both which I think has more green to them.MWMULES: Is that the USMC green?
Maybe you can scuff them off with a worn 3M pad or something. Maybe they will scrub off with Pre-Kleano or a strong soap. Maybe you can dust over them with a very thin, light topcoat.Well about 10 days ago I sprayed my Jeep Wrangler with the CARC substitute Behr paint. I used floetrol to help spray it and used a HVLP gun. It came out great. It had about 2 days outside to dry then moved it the garage for 2 days due to rain. Then moved it back out for about another 4 days of decent no rain weather. Well on day 9 or 10 it rained for about an hr and now that everything is dry I have these ugly run marks on just the vertical surfaces. It isn't runs like sags as if the paint was sprayed to heavy or thinned from the rain and ran. It is more like what a vehicle looks like that doesn't have a good wax job and you let air dry after washing it and it shows where the water dried on the sides in long runs.
Anyone have this problem? Is there a way to get rid of it without repainting or is that it? How do I keep this from happening again?
