Scrounge41
- 1
- 16
- St. Augustine, Fl
Went out and took one. Just hold it in place with one hand and shoot with the gun in the other.
Thanks for the heads up. I've been getting PM's of guys saying the same thing. Seems the tints changed. I'm on my last gallon of paint so I'll have to get some more paint in the coming weeks.@wsucougarx, don't know if it was discussed before but I bought another gallon of the behr paint using your original codes and Home Depot/Behr changed up their codes so they can't match it 100%. They said they can match the paint from a sample or try to get close enough to the original. I opted for the guess and it came out pretty close. It goes on super light, almost a lime-ish color but dries darker.
There has been a lively discussion on here about the benefits and drawbacks of the different types of paint spray guns. Depending on your budget, I understand others have had good results using only the gravity feed inexpensive guns from Harbor Fleece. Personally I would try and locate either a pressure pot setup or an airless rig to do the underside. If you take your cab roof off you should be able to spray with your gun about as far as you will be able to see. Another option would be just to roll the areas with a hot dog roller. A tip a painter once showed me was, before you use a roller with nap, stretch out a length of masking tape and step on one end with your foot and hold the other in your hand. Then take the roller mounted on the frame and roll it back and forth on the sticky side of the tape. It takes the loose fibers off of the new roller so they don't end up in your paint job. Good luck.So im curious about doing this to my truck using exterior latex house paint. but I'm wondering how you guys do under the box and under carriage, also in between the cab and box? Oh, and one more thing is there such thing as a choco camo in a woodland color scheme? or say multicam? I kinda want something with white in it, because I believe theres more white in woods and praries than one might think.
can you give me info on this paint...brand,color,paintcodes.here are some more before and after pics of my truck
an on going project but I am sold on this paint![]()
Post 87 off this thread has a pic of my paint code, post 135 is my truckcan you give me info on this paint...brand,color,paintcodes.
im priming my truck tomorrow and hopefully painting it this week but im very skepticle about using this behrs paint.
that would be fine I painted mine outside in 50-60 deg temps and 40 deg overnightsI'm priming my entire carb with rust inhibitor tomorrow. Then im going to shoot the cab green, i love your color. Not making a show truck by any means. Its supposed to rain monday-wednesday so i will just park it in my shop with the heat around 70 degrees i suppose will be okay.
