Sure did.Did you reseal the head bolts when you moved the bracket?
Perfect, I didn't want to see you chasing leaks when she's all together.Sure did.
What do you mean by "resealing" the head bolts?Did you reseal the head bolts when you moved the bracket?
All of the head bolts go into the water jacket on a T245 block. They will leak coolant if the threads are left unsealed.What do you mean by "resealing" the head bolts?
Good to know. Does the extra lubrication on the threads of the thread sealant affect the torque values at all?All of the head bolts go into the water jacket on a T245 block. They will leak coolant if the threads are left unsealed.
