DieselBob
- 13
- 38
- Arnold Maryland
Very nice work on the wiring and circuit breakers AN/ARC186.
I wondered what those were, never would have guessed they were holders for the soft top bows. Thanks for the pictures!Fitted new bows to my soft top frame...fits good Also put on the nifty holders that came with the new bows.
i agree Don. good looking rig! is that the one that had the camper built in it when you got it? id like to see more detail of the fender mount leds. heres my 109 before and now.. figured id show how i parted it out some.. more mods coming.
Med. grit sand. Hood has thick enough steel to not warp. Fun thing was removing all the flaking off of the sealer the gov. put on the foam insulation. After I wet the foam and let it soak some, you can pull the (Latex? ) sealer off. Now hunting for a new sealer paint to refinish the foam.What blast material did you use on the hood?
Where did you get your spot lights on your mirrors from?Finally finished up the installation of my fans, completed some wiring and the install of my drivers flood light, going to change the bulb out to a spot.
i like it too. go with it opcorn:Got a little more paint sprayed today. After using bondo on the bumper to fill deep gouges, Id say it turned out good. Any comments on the color? I like it.
