- 6,426
- 4,982
- Ft. Lauderdale, Florida
Anybody have source for the "plastic" fuel hose? Please help. The actual nomenclature; a source to procure it from? Did you find the source for the plastic fuel lines? I need to replace all from the fuel pump outlet to secondary filters all the way back to the hydraulic head overflow and the FDC inlet. The TM 9-2320-361-20P section ll fiqure 17 says tubing, made from tubing P/N TD2.57420 with a part number and with an SMR code and a CAGEC number. Basically indecipherable to me.TM9-2320-361-20P is the parts manual for the M35. Aw heck......see the attached pages....you should be able to figure it out from them.....
So far I have not found where to by the "plastic" hose. It has all been cut and jury riggerd and leaks.
