M35A2 Deuce fix it
frank8003
4,988
Ft. Lauderdale, Florida
TM9-2320-361-20P is the parts manual for the M35. Aw heck......see the attached pages....you should be able to figure it out from them.....
Anybody have source for the "plastic" fuel hose? Please help. The actual nomenclature; a source to procure it from? Did you find the source for the plastic fuel lines? I need to replace all from the fuel pump outlet to secondary filters all the way back to the hydraulic head overflow and the FDC inlet. The TM 9-2320-361-20P section ll fiqure 17 says tubing, made from tubing P/N TD2.57420 with a part number and with an SMR code and a CAGEC number. Basically indecipherable to me.
So far I have not found where to by the "plastic" hose. It has all been cut and jury riggerd and leaks.
1,188
Use DOT air brake line. Use inserts and standard ferrules.
A search for "fuel, ferrules, inserts, line" shuold pull up some threads on this.
caliber1
Elcho, Wisconsin
Frank, there is an Amazon Hose and Rubber in Miami that will likely have anything you need, hose, fittings, ferrules, and all. Good luck.
frank8003
4,988
Doghead, Thankyou for information leading to successful restart of my deuce. I want to post the information that I have learned and am unsure if I whould put it on some other thread or my original "M35A2 Deuce fix it" thread.
Now I have a SS website question.
I am unsure if I am viewing all the replies the site says I have to the "M35A2 Deuce fix it" thread.
How do I set it for emails notification so I can see the replies or do I go to the thread and view them some other way?
We thank you again for your help.
Frank
frank8003
4,988
Deuce front end steering wheel to tie rod
Has anybody replaced the steering box and or related parts on a M35A2 from the steering column all the way to the tie rod ends?
There is not so much on SS that I can find about the steering components.
This truck steering shaft was cutoff and I need to know what to do to put it back.
Even if the parts were free would this be possible for one guy to do in the yard?
I have seen all the TM's and it looks doable
I solicite comments.
phil2968
Lakeland, Florida
I guess you have a cylinder on the axle for steering? Yes you can replace the steering box by yourself. You will need to jack the engine over to get it out. Nice pump set up.
frank8003
4,988
motor air Wipers Windshield green two each
M35 A2 1969 Deuce wipers only sort of work sometimes.
Have new arms and wipers and have adjusted pressure on glass.
Have dissassembled reassembled both air motors .
No workie good.
No money no inclination to go with electric wipers
So I just have to ask everybody on SS................
Does or has anyone have air wiper motors that really work?
Many members drove these trucks when NEW.
So did I but never once had to use the wipers.
I have no reference to what they shouled run like.
Has anyone repaired them?
I see new ones for 75 bucks each.
Does anyone have any used or takeoff that I can try to fix?
Where it is so far is there is nothing wrong with the driven part or the O-rings
but the secret is in the primary air input head. There is fragile cork gaskets in there and I did not disassemble that part.
Is there rebuild kits out there someplace?
Reminds me of my '55 chevy. I just went down the line of 30 or so of them and took all the wiper motors. I just swapped them out until I got a good one. Had no money then, same now.
I have to fix what I got.
Anybody know where rebuild kits, used motors, or cheaper new motors can be had?
I pictured what I did so far.
Pictures for the General.
frank8003
4,988
GAA MIL-PRF-10924G axle seal ng
now this is interesting. Like how did we get to MIL_PRF_10924G and where do I buy it and how come bearings fail on the Deuce but not on the chevy
there is more, I'm trying to find it
Have to grease the truck
Have to buy GAA
had to find out whatitis first
GAA is
from http://www.tardec.info/GVSETNews/article.cfm?iID=0802&aid=10
MIL-PRF-10924G
The Army uses National Lubricating Grease Institute Number 2-consistency grease covered by military specification (MILSPEC) MIL-PRF-10924G, Performance Specification, Grease, Automotive and Artillery (GAA)
Another Ahab
4,783
Alexandria, VA
A guy walks up to a doctor and says, "doc, it hurts when I do this".
Doc says, "don't do that".
Thats how much info you gave us.
Guy walks into the doctor's office, says "Every time i sneeze, I have an orga**."
Doctor asks "What are you taking for that?"
Guy says "Pepper!"
Mea Culpa: Not intended as a hijack, but the set-up was just too good to pass up...
iatractor
19
SE Iowa
I have air operated wipers on my deuce. Not thrilled with them. The only thing consistent about them is how inconsistent they are in operation. So needless to say, I tend to operate the truck on days when it doesn't have any rain in the forecast.
