mxcobra
- 0
- 0
- Cape Cod MA
Good replies ... I will be checking those bolt this weekend.. But I don't think I will roll it over ![Wink ;-) ;-)](https://www.steelsoldiers.com/images/smilies/icon_wink.gif)
Fixed it for you!Gimp is very "talented".![]()
If this is the type of WORKMENSHIP that went into this bob build, I would If I was you, look at the rest of the build VERY CLOSELYThe spring mount just has the two bolts on the top and the bottom was "cut to fit" around the other piece. This seems like a flimsy set up for the spring hanger. It just sort of fits around the other metal piece that came loose. The other side has the normal mounting holes underneath the spring hanger.
I got to figure out a better way to mount it. They did a real monkey job of putting this thing back together.
