Nate475
- 0
- 0
- Glen Burnie Maryland
I finished the Rosscommon 12 volt conversion on my 1986 M1009 3 days ago. The conversion was relatively easy. The worst part involved finding the correct 8 gauge ring terminals and splices. I checked 22 stores before finding a forklift battery supply company that could special order them for me. They hooked me up well and then yesterday I found a Napa store 5 minutes from my house that I wasn't aware of and they had everything I needed, lol. Napa now gets all my business regardless if it's in stock or not.
I installed a high torque 12 volt gear reduction starter for a little extra power on cold mornings. If you do the conversion you are going to need a new rear starter bracket along with a new bolt set. The new bracket was for a 1989 Blazer. They went to the new gear reduction starter that year so any rear starter bracket for a 6.2 or a 6.5 liter from 1989 forward should fit the new 12 volt gear reduction starters. I also swapped out the 12 volt gauge because the 24 volt gauge flat lined after I did the conversion.
My overall opinion so far is good. My truck runs better without the second alternator. It has better acceleration and it should get better fuel economy as well. It also took care of the short that was in the wiring going either to or from my gen 1 light. In my opinion less components and lower voltage equals greater reliability. If I was a collector I would feel differently but my CUCV is my primary vehicle and the 24 volt system didn't meet my needs.
My next big project is to install an in dash aftermarket AC system. I'm going to mount the compressor where the gen 1 alternator used to be. That way it won't conflict the Banks turbo system that I'm going to put on later.
As far as cold starting is concerned the 24 volt starter has a slight advantage but nothing worth being concerned about. Ever since I replaced my injectors and my glow plugs my truck has been easy to start anyway, so no regrets on that front.
And lastly, I will speak to those who like to say, "No one will ever be able to help you when you have a problem", now you don't have to say that in post to me, lol.
The bottom line is if you save your parts you can always change back in a few hours. And it's not that hard to figure out a problem if you have one. By changing it over you actually simplify the system so as long as you understand it, it won't be a problem.
