kabar1
- -1
- 0
- Cleveland Tennessee
![photo (19).JPG photo (19).JPG](https://www.steelsoldiers.com/data/attachments/299/299763-c0f795ce97b21c1c565f912ff24704f0.jpg)
![photo (16).JPG photo (16).JPG](https://www.steelsoldiers.com/data/attachments/299/299764-8248376e9516f8bb463c6ab8331f915d.jpg)
![photo (17).JPG photo (17).JPG](https://www.steelsoldiers.com/data/attachments/299/299765-e848c55df2342150bf6308722e02a69b.jpg)
![photo (18).JPG photo (18).JPG](https://www.steelsoldiers.com/data/attachments/299/299766-ff89f24db95e9ebb4c70f3028a20eb59.jpg)
No it was a little noisey he said it may need to be shimmed I brought a mechanic friend w me two and he agreed , I contacted the seller shortly after all the issues started to develop and be said I had no idea , he's a cop in Gorgia and said he wished there was something he could do cause he can't afford to have a bad reputation being a police officer, I said u can give me some money back he said he couldn't , he posted here several times what a great running truck it is , it does run very well but I've had to pretty much replace or work on every excessary alternators belts pumps etc.Did the seller disclose there was an issue?
This is the bracket for the gear reduction starter? Correct?bracket part number 23502557, bolt part number 15544950. Both available from here...
http://www.gmpartsdirect.com/?CFID=...4bb56dd9f-7676966F-D4F0-B4AF-F13BAA4326490A4A
Order both. The bolts only come in packs of 5. Share with your friends.
In the last pic I see the mounting boss on the block. If the threads are good you just need a new bolt. Metric by the way.
Yup, I don't think the bracket for the direct drive is available new anymore.This is the bracket for the gear reduction starter? Correct?
