Starter killing flywheel
1,191
It's on an engine stand.
Warthog
244
OKC, OK
I stole it from someone. It was on the web so it must be free.
1,191
And true...
kabar1
-1
Cleveland Tennessee
To add to the level of difficulty they also threaded out the whole bigger on the block and starter, I got a gear reduction starter, could i make the hole bigger, or could I tap the hole deeper and put a longer bolt in there, how deep can i go w the right handed hole?
Warthog
244
OKC, OK
There is a company called Lock-N-Stitch their specalty is repairing cast iron. They make kits you can buy for do it your self cast iron repair
Denny
I contacted Lock-N-Stitch about my block and their reply was to remove the engine and braze on a new ear and redrill the hole.
kabar1
-1
Cleveland Tennessee
I contacted them too and sent pictures but got no reply , haha , I discovered the other hole is elongated and the flywheel is worn bad from grinding , I'm wondering if it would b more cost effective just to find a good engine , I'm not sure the problem wouldnt resurface again if by some miricale I was able to perform the repair correctly and get every thing centered correctly - input welcome
MarcusOReallyus
819
Virginia
If the other hole is elongated, you no longer have a reliable reference for positioning any repairs.
I think you need a machine shop to fix this. I think it's gone beyond DIY territory.
o1951
155
Bergen County, NJ
If the ring gear is trashed, it will chew up starter pinion. That has to be addressed.:sad: I think you are looking at some serious money for proper repairs. To bad this was not caught sooner.
Warthog
244
OKC, OK
Just think. It could have been a GL truck with all the issues and a bent driveshaft or cracked transfer case.
kabar1
-1
Cleveland Tennessee
Very very true all I can do now is move forward , I believe a engine swap may be the cheapest solution? Any idea where to find a good one ? Do the hummer take outs drop right in?
Warthog
244
OKC, OK
The HMMVW engines are a drop in. Just need to swap the accessories and fuel shutoff on the injector pump. And the oil pan.
Watch out if the HMMWV engine had a sepentine belt. The water pump pumps in the opposite direction.
Warthog
244
OKC, OK
The ip is almost identical. The Hmmwv uses a 24v shutoff. The Cucv is 12v. Just the cover needs to be changed out.
