1990 bmy 923a2
Suprman
707
Stratford/Connecticut
There are a few ctis problem/solve threads I dont know how to link but if you tell me what its doing or not doing I can tell you how to fix it
bigboy44
Ava, MO.
Suprman, I haven't even tried to plug it in since I don't know how it operates and I haven't got to the TM yet either. I am still in check out mode. I do remember reading not to plug it in when the switch is on if I remember correct. Thanks for any advice in advance.
Suprman
707
It will automatically come on and when the system sees 120psi in the tanks it will do a pressure test then try to fill at hwy pressure. Plug it in and start it up and see what happens
bigboy44
Ava, MO.
I tried the CTIS, I started the truck and let the air build to 120 then turned it off and plugged up the CTIS then restarted the truck. Aii I could get was the 5 flashing lights, I tried to press different settings but they did not do any tire adjustments. I could hear a blow off of some kind and the buttons would highlight when pressed but did not appear to do anything, I even tried driving the truck around but nothing!
Suprman
707
It sounds like you have a fill side air leak. Go to the wheel valves there will be a standard schrader valve press each one and see if a little air escapes. If not the wheels probably have schrader valves installed in the stem. If air comes out then you have to look for an air leak. The system does pressure tests you will hear the air escaping usually from a wheel valve or one of the lines going to the hub. Someone can sit in the cab and press the hwy button it will do the pressure check and you can go from wheel to wheel looking for the leak.
