- 6,854
- 677
- 113
- Stratford/Connecticut
There are a few ctis problem/solve threads I dont know how to link but if you tell me what its doing or not doing I can tell you how to fix it
Suprman, I haven't even tried to plug it in since I don't know how it operates and I haven't got to the TM yet either. I am still in check out mode. I do remember reading not to plug it in when the switch is on if I remember correct. Thanks for any advice in advance.There are a few ctis problem/solve threads I dont know how to link but if you tell me what its doing or not doing I can tell you how to fix it
Dec. 08 is what is on the tag!Nice truck. If you stand on the drivers tire and look at the engine data plate on top is the date of manufacture I bet you will find that it's a new motor from 08 or 09
I tried the CTIS, I started the truck and let the air build to 120 then turned it off and plugged up the CTIS then restarted the truck. Aii I could get was the 5 flashing lights, I tried to press different settings but they did not do any tire adjustments. I could hear a blow off of some kind and the buttons would highlight when pressed but did not appear to do anything, I even tried driving the truck around but nothing!There are a few ctis problem/solve threads I dont know how to link but if you tell me what its doing or not doing I can tell you how to fix it
