Driver_Neil
- 2
- 0
- Essex, UK
Fitting rubber pads to the OT-90's tracks is not a quick or easy job. The only pads that will fit are BMP-2 ones. Last I heard they were about £16 each here in the UK with a month or two waiting list. And you have about 92 each side.... To fit them you (Lee, the owner) will need to jack the vehicle up and support the weight then remove the tracks and break them down into individual links. Each pad will then need two holes plasma cut into each link for the mounting bolts. Once this is done you bolt the pads into place and then reassemble and refit the tracks so you will also need a set of track tools to do this with. I've been trying to get a set for 5 years now....
I had my pads fitted by the dealer when I bought it - a long and painfully expensive story involving the UK's VOSA Gov't agency.![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
