Grease boots Deuce and 5 ton too
First, yes...let me state the obligatory "I have searched and I've read the TMs", but I still can't find out whether or not I just keep pumping grease into the front wheel grease fitting indicated on the attached photo until I see grease coming out of somewhere? I realize you pump most grease fittings with grease till you see grease escaping, but not sure about this. Thanks for any help you can provide.
Frioman did good with this question. Read on. I am learning that the 1/4" hex driven plugs that should be removed were fastened last time by Godzilla.
It was just yesterday I was looking at those plugs and took pictures meaning to ask SS what that was about. I need to grease the truck without breaking anything. Don't want to fail my boots. Frioman asked good question, Thanks
LO 9-2320-272-12 card 19 of 33 is picture
Deuce LO 9-2320-209-12-1 page 22 of 34 shows letters N+P for same thing as K+L on the 5 ton
Then in LO 9-2320-209-12-1 page 7 of 34 it has a disclaimer to go to note 11 (about the letters N;O;P) as to putting the GAA into the front wheel steering knuckle bearings and universal joint. It says take both plugs out and fill until it comes out the other hole, doesn't say how, someone was supposed to teach me that.
Have to make air tanks too.
and pictures for the General
![air tanks.jpg air tanks.jpg](https://www.steelsoldiers.com/data/attachments/331/331699-3d3f9876fa18b172122341952ccd06ce.jpg)
