hoplite666
- 1
- 18
- Fairfax VA
Pulled the M1009 in the shop to load up some things. Went to start it up to pull out. Nothing but a click from the relay. Happened to have a spare starter relay in the glove box. Popped it in. Nothing.
Inspected wiring and found a wire on the power block nearly totally frayed. Patched the wire. Starter spins but doesn't engage flex plate.
Put original relay back in and with no key in ignition starter spun and engaged flex plate and began to run away.
Disconnected relay
Put spare relay back in, sparks flew and starter ran away with no flywheel engagement. (yes, I should have disconnected batteries)
Ive got all the parts for the doghead mod but just haven't gotten around to doing it.
Gonna do doghead tomorrow
Question.... could faulty starter relay cause no flex plate engagement? Before relays totally went out and ran away i could crank and starter with spin w/o flex plate engagement.
At this point I'm assuming my heavy handedness and lack of battery being disconnected caused the relay's to pop and original fault was that loose wire.
Should I plan on pulling flex plate inspection cover tomorrow or will the doghead mod take care of my problems?
Starter is newish
Batteries will be trickle charged tonight.
Disconnected relay
Starter is newish
