- 14,606
- 4,691
- Buchanan, GA
Ditto!Also check for loose bolts.
Thanks for letting us know what you found and taking a pic- that will be great information for others with similar problems!Do you see what I see…. Found it.. Now just need to order a new U joint.. You guys were right it wasn't inside but sure as heck sounded like it. It was the one connecting to the pumpkin on the rear diff. There is a little play in it which is causing the ping sound..
