- 3,753
- 1,538
- North Carolina - FINALLY !
When I did my house, they used what looked like a really long hedge trimmer
I found a You-tube video that shows how the pro's do it. It's a Sawzall with a very long cutting blade!Progress
Sounds like a plan! If not you can always get the 3 handsaw deal. One for you, one the the wify and one as a spare. Hope it goes fast and easy for you.I think I'm going to try to make a blade for my sawzall.
Honestly, we haven't touched it since the GA rally. And the way things usually go I'll probably keep putting off working on it until I realize the next rally is less than a month away, panic, then bust my butt trying to get something done on itWHATS THE LATEST ON THIS RIG?? - sorry about the CAPS - I'd love to see some more pics of your progress. As for cutting the foam (which you've prob long since finished) - There are hot wire tools that are adjustable width so you can adjust it to 20" or so and cut each bay at a time.
Thanks for sharing - keep going!
Im currently in the design phase of a slide out on my m971.. its a LOT harder then it looks.. but doable.. it is almost impossable to do a flush floor design with the way my trailer is structured, but with a M129, i think the frame is in the center, and that would make it easier for a flush floor.. I plan to do a raised floor, with the slide floor 2"-3" above the main floor.. the slide will be 2'6" deep, and 17' long.. on BOTH sides..Looking forward to seeing more on the build! Looks great so far. Just a general question, has anyone tried adding a pull out or slide out? I think it would be a lot of work but just thought it would be a neat idea.
