- 2,052
- 56
- 48
- Milford / Michigan
Would this booster pump seal be in the injection pump gasket and o-ring kits that are available? I have a kit but I do not remember seeing the seal in the kit, but maybe it is/was?
I checked my gasket kit and i did not have the seal in my kit. I just ordered the kit from SECO and it was $29 plus shipping. Price went up.Thanks for the lead on the parts. I just ordered a kit from them, $19 + the ride = cheap peace of mind!
That would be a toss up what would be faster and easer. Myself I would pull the IP and replace the seal in boost pump and oil to IP feed line.Looks like I may be doing this to my truck very soon. Its almost tempting to just stick a whole new IP on and call it a day.
Depends on if you watch GL real close or not.Is it cheaper? Absolutely not!
Do you have the part number of the oil seal?i bought a genuine oil seal at the local injection shop for $6
I think if you pull that plug out and had the engine running, you would be draining your oil out too as it the oil pressure line would keep pumping oil to the injection pump.Do believe you can also check for fuel in the IP by removing the rear most bottom plug out of the IP and see if it is draining out fuel.
I was able to diagnose my MBP leak by running the in-tank pump.Yea got to do it with the engine shut down but the IP has a belly and believe you can check the boost pump for leaks with the intank running.
Okay. In previous comments it sounded like it was an o-ring seal. I haven't had a chance to take apart the MBP, so I have not idea what it looks like. Thanks for the heads up. I won't be looking for an o-ring.not an 'o' ring, it is a seal. remove the 2 front motor bolts and the LR mount bolt and push the front of the engine to the right, it will come out.
I thought mine was $35 shipped as well. But, then I got an invoice for $53 showing I was charged $18 shipping and handling.OK
Got mine in the mail today, $35.00 including shipping. AMBAC # KT9062
Crap!I thought mine was $35 shipped as well. But, then I got an invoice for $53 showing I was charged $18 shipping and handling.
