jrosbo
- 5
- 18
- Vandalia Illinois
Does anyone know what an OA331 weights? I need to buy a new engine stand and the local stores only have 1000 lb. stands. Is that heavy enough?
Did you see the previous post in this thread which answered your question?i hope everyone here is well and alive.....
sorry to respond here some 8 years after this thread was started, but i just found it in my search for the answer to an un answered question:- how much does this OA 331 engine really weigh??
i pulled mine from a REO M-35 a few days ago and it was H E A V Y.
my guess was about 800 kg = 1760lb.
can anyone give good and documented answer to this question??
thanks
Barry
You clearly haven't a clue. You were given the answer straight from TM9-1819A.yes i did.
one reply said 872 lb which is obiously wrong and the other said arround 1600 as an evaluation.
i wondered if someone actually knows the answer.
the rest of the truck is here, but here is far away - tel aviv israel....
it's one thing to quote from a manual and another to actually pull one out.You clearly haven't a clue. You were given the answer straight from TM9-1819A.
I have pulled several OA331 and several multi. In fact, I pulled an OA331 using a cheap parts store engine crane. Not going to do that with a multi. I stand by my prior comment.it's one thing to quote from a manual and another to actually pull one out.
the engine i pulled out was no way near 400 kg. more like twice that weight.
are you sure it was 872 and not 1872???
