OA331
1,814
RE: 331
I thought they were lighter than that. Heck, the multifuel is only 1800#. I had no problem extracting one with my red neck engine picker upper but then again, it was attached to 2 trees. not one.
jrosbo
Vandalia Illinois
331
If anybody needs a complete engine rebuild gasket kit or any gaskets for that matter, get on Ebay and search under REO. There is a guy in Chicago that is selling them. I asked if he knew what they fit and he didn't so I took a chance for 30 bucks and I when I got them all the gaskets were just like the ones on the engine I am working on now. He has another set up for sale right now.
the frog
tel aviv
i hope everyone here is well and alive..... :)
sorry to respond here some 8 years after this thread was started, but i just found it in my search for the answer to an un answered question:- how much does this OA 331 engine really weigh??
i pulled mine from a REO M-35 a few days ago and it was H E A V Y.
my guess was about 800 kg = 1760lb.
can anyone give good and documented answer to this question??
thanks
Barry
JasonS
126
Eastern SD
thanks
Barry
Did you see the previous post in this thread which answered your question?
the frog
tel aviv
yes i did.
one reply said 872 lb which is obiously wrong and the other said arround 1600 as an evaluation.
i wondered if someone actually knows the answer.
the rest of the truck is here, but here is far away - tel aviv israel....
the frog
tel aviv
i know that the LD 465 weight is apprx. 1800 lb but it is 478 cid and the 331 is only 331 cid, so there may be a difference there although the 331 is older.
JasonS
126
Eastern SD
yes i did.
You clearly haven't a clue. You were given the answer straight from TM9-1819A.
the frog
tel aviv
it's one thing to quote from a manual and another to actually pull one out.
the engine i pulled out was no way near 400 kg. more like twice that weight.
are you sure it was 872 and not 1872???
JasonS
126
Eastern SD
I have pulled several OA331 and several multi. In fact, I pulled an OA331 using a cheap parts store engine crane. Not going to do that with a multi. I stand by my prior comment.
welldigger
15
Benton LA
The literature I found on the oa331 said fully dressed the engine weighs 872 pounds and with transmission it weighs just shy of 1200 pounds.
A fully dressed multifuel is about 1700 pounds without a transmission.
