- 3,218
- 383
- 83
- Tonopah, AZ
Anyone know if you can run single phase on the MEP805A Generator?
Thanks!
Thanks!
Thanks for your input, I ended up getting a Mep-005a.I know it's been a while since you posted your question and it may no longer matter to you.
I have an mep-805a and it does single phase 120 or 208. It's very quiet, very clean power (no problems for my computers) and acts as if it could go on that way forever.
Sorry, I didn't see your post until now. Yes, 120 off each of the three legs. 2 legs = 208. You only use two to run your house. I recently put a three phase load center on with a second 50amp outlet so I can pull more if I want to. I don't know why I would need to.You mean it does 3 phase 120/208 not single phase no?
I am pretty sure that is what you mean that is why you are pulling 208 between any of the three line lugs not 240. So you are only getting 2/3 the power output of the 30kw rated power it can produce. Post up a video of it in action I would love to see one running. I just picked up an 803a a few months ago and have two 005a's. The 005a I did the conversion to put it in low zig zag wiring for true single phase 120/240 output however as mentioned here they are loud. Mine sits in a shed with exhaust ported out and is not to bad from 100 ft away just a low drone but still some noise to it.
That would be my Jeep.What's that tire on the left in the first pic? Looks like a tractor or a monster truck!
Nice paint on the generator, too.
