rtbcoop
- 0
- 6
- Tyndall AFB, FL
I've been doing a lot of CARC removal lately so I figured I would add my
and experiences.
Stripper wheel: Not the crappy type that goes on your drill, the nice type that attaches to your angle grinder. Works AMAZING! Very fast and cuts right through the CARC to the bare metal without cutting into the metal itself. Does not work so well in small spaces. Also on the expensive side ($10 each). One wheel will strip a hood before it needs to be replaced.
Chemical stripper: I used Klean-Strip with plastic wrap. Works well but you usually have to use two coats. Works well in tight areas. You do not need to get the aircraft rated type, just the standard stuff from Home Depot. Costs about $20 per gallon but a gallon goes a long ways.
Toast it: I will not endorse this method for the sole fact that I do not want the EPA knocking on my door. However, this method is very cheap and works well. Grab a large propane torch (like the Inferno) and go to town. MAKE SURE YOU ARE UPWIND AND WEARING A VERY GOOD RESPIRATOR!!! This smoke is HIGHLY toxic. One whiff and you will be talking like Ozzy the rest of the day. Because of the smoke, I don't really suggest this method.
Craftsman Sand Blaster (mentioned earlier in this thread): Works ok but only on very small detailed parts (window frames for example). Does not do well on large areas because it takes so long. The benefit is that it is extremely cheap if you live close to the beach
Pressure Washer: Did not work but mine may not have been powerful enough.
Overall, I would suggest the stripper wheels or the Klean-Strip. Both work well, are fast, and fairly cheap. Hope this helps.
