Wile E. Coyote
- 75
- 28
- Lynden WA
Sigo said everything I was going to say. Tons of DAGRs came out. Mike Murphy was selling them on his website for about a year - not even an EUC requirement. They list regularly on Ebay (very regularly...maybe even now at decent prices, though conditions and revisions are all over the map. Basically with a shift from Red Key to Black Key architecture for the crypto loads...nobody's going to be doing anything with them remotely harmful to national security anyway...which is probably why the alphabet agencies have unofficially backed off in terms of calling up Ebay and Craigslist vendors.
On Blue Force Tracker - a number of functioning MT2011 antenna/transceiver units were sold on Ebay, and a collection of demilled ones (connectors punched in - one was intact) were recently on G503. Austin *regularly* has the power supply cables, transceiver cables and switching boxes for them in addition to the different styles of mounts (HT rear sponson; HT or other variants front windshield.) Just about all of the various interface cables for FBCB2-BFT and FBCB2-EPLRS were listed at Austin's Ebay store - but it's a matter of going through the installation guides etc. to work out which ones you need if you're trying to go full FBCB2. Everyone thinks the FBCB2 computer setup is the same as 'Blue Force Tracker', but it isn't, really. In early days they just had the BFT version of FBCB2 using the MT2011 satellite transceiver for data connectivity, but later they also had the EPLRS version which used the UHF EPLRS transceiver in place of the BFT's MT2011 sat transceiver. Austin had cables for both setups...just about all of them, as I recall. I'm sure there were other variations, but those are the ones I know of. I think it all worked only with x-version or newer of the VAAs too, so while that museum setup of the RT-1439s pictured is really awesome (salutes) - FBCB2 wouldn't have been in a vehicle with a single-mount RT-1439, or to my knowledge any vehicle installation this side of at least a SIP SINCGARS - but subject to correction - and anyway, it looks cool for the public who won't really know of or care for the minutiae.
You can configure the serial port output of both PLGR and DAGR to output only the needed NMEA 'sentences' used by external map-on-the-move programs like Google Earth etc., which is covered in manuals readily available online, and I think in the Google Earth documentation as respects what's needed. Sometimes PLGR returns the wrong date for some reason when used in conjunction with Google Earth, but I've never bothered to determine why as the rest of it works perfectly. You can experiment with what the various NMEA sentences do when hooked up to the mapping programs and work it out for yourself in the absence of any documentation. I can't readily recall which ones I use for my own setup.
Not to hijack the thread here, but if anyone's got a CPU for FBCB2 (doesn't have to be JV5), I could use it - as I've pretty much got the rest of it
