rustystud
- 3,371
- Woodinville, Washington
You let it set for 3 years with Berryman B12 in it ?
Wow, whatadeuce, talk about "picking up where you left off " - almost 3 years ago!Here it is June 7, and having tested the compresion again, it came up a little. I shall try ot start it with the help of brake cleaner, and if it don;t run, a pull start...
Buy the crane ! Buy the crane !No along with the motor he could buy the 5 ton crane too.
Buy the crane get the multi fuel motor free.Buy the crane ! Buy the crane !![]()
With that crane he can move that engine over the house if he needed to. The wrecker can only lift about 10ft right ? That crane can probably lift over 30ft correct ? So after he installs that engine he needs to build a new barn to store the truck in. With the crane he can lift roof beams and roofing and everything else needed to build this new building. After building my own home I wished I had bought my own crane instead of paying people to do the lifting for me.The rough terrain doesn't hold a candle to this one, imho, of course:
http://www.steelsoldiers.com/showthread.php?140647-1972-IH-5-ton-wrecker&highlight=
