notsosanestan
- 1
- 0
- NNJ
Hello Midnight,Here's the pics of my hitch on my 1009.
The support bar for the Pintle hitch has been removed because the hitch won't fit on there with it. As I mentioned in another post, I'll probably cut the bar down and re-weld it in between the support arms of the hitch. Then fasten everything back down and it should be twice as strong.
I had to bend the safety chain loops up. A big sledge hammer took care of that.
On the passenger side, I had to remove a nut off of one of the bolts that holds D-ring bar to the frame. I couldn't get the nut onto the one of the bolts for the hitch with it there. The bolt is still in as you see in the pic and it can't come out because of a support bar for the bumper. I'll probably just weld the bolt in so it won't move around and it will add strength back to the D-ring.
I used existing holes in the frame, didn't have to do any drilling.
I've included a pic of the wiring harnass as well. It is on the driver's side.
I've also included some pics of the Cherry Bomb glasspack mufflers that I put on. Bought those at Autozone, much cheaper than the OE mufflers. I have them re-routed to exit out in front of the rear tires now.
If anyone needs a better pic or a different pic of my setup, just let me know.
Half the work? Only if you have a cutting torchCheck out post #24 above that is a mean honking hitch and it looks ready to tow anything that the CUCV can tow. With the use of all the factory reinforcements in place and no irreversible modifications to the original design. Very nicely done and well with in budget. I really like the reinforcement under the receiver tube. I think that would be stronger then any bolt on under bumper receiver class 3 or 4 receiver and half the work and expense. Very nicely done Keith_J. and it looks like it belongs there not a poorly fabricated add on.
You'd better look in the mirror on that one. Hope you don't ever hurt someone with that ignorant crap you put together.Your post is a sign of what's wrong with this country. .
