UPFINN
- 4
- 18
- Ishpeming Michigan
Just got back inside awhile ago.
It took me around 8 hours to get one coat of rustoleum primer down on all visible frame and body sheet metal. I ended up using 1 gallon. Does that seem right, too thin? I'm thinking of doing another coat.
Mixing the reducer and cleaning the mess that happened during the process took the most time. I also found out that you should not tip a plastic hvlp gun upside down. The primer got in the air passages and coated everything inside the gun. Since no solvent traveled through the air passages, the primer was baked on from the hot supply air and can not be removed. It still works, but every plastic part inside the gun is red now. I hope there is no contamination issues with pieces flaking off while painting.
