hambone
- 508
- 93
- El Dorado, Ar
Thanks, I will post anything I find, has anyone ever ordered any window felt for the window channel, mine are worn out and floppy windows suck. Hambone
Looks to be just what the doctor ordered; nice find.Oh now this is cool!!
If you have the 1-3/8 bore cylinders, those will work great. They will be loose on the 1-1/4 bore. You can put a zip tie around the boot to tighten it up, but I am not sure how that would hold up or for how long.About to order wheel cylinder boots, NAPA 14509 if they are available, NAPA's website shows 11/2" diameter?????
WOW! I haven't even pulled mine apart to look at them, glad I only bought 4, was hoping I wouldn't have to spend $800 on wheel cyls.Before you assembly your truck, check this thread.
http://www.steelsoldiers.com/showthread.php?143929-New-Wheel-Cylinder-Issues
I am having problems with my new wheel cylinders that look just like yours. I did not get them from the same place as you so the internals may be different.
