HanksDeuce
- 252
- 83
- Prairieville, LA
Today I finally fixed my air system pressure issue. After several calls to Cummins, Haldex, and a few others followed by disconnecting this and re-testing that I decided to throw some money at the problem. I drove down to the local Truck Pro and bought a replacement governor for my Holset QE296B gear driven air compressor. I plugged the necessary ports and installed the governor. After I reconnected the sensing line from the factory deuce air tanks I fired the deuce up. A few minutes later I'm up to 125psi (cut out pressure). The air system had been giving me fits since the engine was swapped by only pumping up to 75psi. I always figured it was something to do with the governor because I ditched the air dryer setup from the donor Bus that I took the engine/tranny out of.
Now where did I put that train horn...
