gcbennet
- 7
- 18
- Trenton, ON
I've got a pair of new batteries to put in and i'm just waiting for the new S3 at this point. Out of curiosity how are the curcuit breakers reset?
i re-read my post...my IPad took out "not". The breakers cannot be reset, they rested upon removing any sort of short or overload.I've got a pair of new batteries to put in and i'm just waiting for the new S3 at this point. Out of curiosity how are the curcuit breakers reset?
Do not use smart box made by Lau Ind. These are so smart they start the HMMWV on their own and have destroyed some!What I get from what you're saying about the breakers is that they're self-setting? I'll pull and inspect them and do a continuity test either way because there's not much left to check at this point. An answer to a previous question- I have no lights. No power whatsoever with batteries hooked up. Every hard connection I can find is clean and tight and I'll test the serviceability of the breakers to either rule them out or confirm that they're open, thus responsible for this ongoing issue.
Now for the S3. I have a new Nartron on the way to replace the KDS that failed. Out of curiosity is one manufacturer seen as having a higher failure history, or are they both pretty much on the same level?
