Gunny65
- 13
- 18
- Bonners Ferry, idaho
Where is a good source for new wheel nuts?
Technically you are not suppose to reuse the lock-nuts. I have heard people use them up to 3 times but the TM and McMaster-Carr indicate these are one time use lock-nuts. I will re-use two wheels worth of lock-nuts and see if there any problems. If there are, I will report back.
I think, but am not sure, that the bolts are 5/8"? (The wheel nuts on the M939 series truck, according to the TM, are 3/4" 16TPI Fine) The 5/8" are possible I guess but that may be for the Deuce and a half and/or older wheels, not sure which applies. My M939A2 uses the 3/4" nominal 16 TPI fine distorted lock nuts, flange style. I provided a link below for both sizes.
Thanks.
EDIT: The original purchase for the 5/8" nuts and die were too small. I went in a read the TMs that apply to the M939 and posted links to the TM sizes that apply. "locknut and threading die, 3/4" 16TPI fine." I was originally incorrect in my visual assessment of the stud size. That is what I get for not actually measuring. Nobodies fault but mine.
Amazon: Union Butterfield 2025(UNF) Carbon Steel Hexagon Threading Die, Uncoated (Bright) Finish, 5/8"-18 Thread Size
From McMaster-Carr: 5/8"-18 | 10each | 90949A112 | $4.59 - the part number is in yellow. |
If you have the 3/4" 16TPI Wheel Nuts (M939 series) Distorted "Lock Nut": McMaster-Carr: http://www.mcmaster.com/#90949a119/=109qyyo
This is the rethreading die 3/4" 16TPI: http://www.amazon.com/Bosch-B46027-4-16-Black-Oxide/dp/B000WACOWK/ref=cm_cr_pr_product_top?ie=UTF8
