Overdrive
- 93
- 28
- Wentzville, Missouri
Have not installed it yet or ran wiring but wanted to share a pic of my custom switch pod for the LMTV.
The case is the standard LMTV switch box that comes with switch holes. I found out quickly that the standard switch holes are too big for the fun 12v switches you can buy everywhere online so I had some spare aluminum sheeting lying around so I fabricated a new cover plate to fit the switches and added a trans temp gauge hole. Will be working on the wiring soon.... lots of projects!
Pic of the panel on the test bench
![switchpanel1.jpg switchpanel1.jpg](https://www.steelsoldiers.com/data/attachments/412/412028-faf934be0656be7b8d523dbd0565d09d.jpg)
will add pics after final install. I have it mounted in the box and in the truck but need to run all the wiring.
As you can see in the pic I am missing the plastic cover for my hand throttle... not sure why but it is bugging the heck out of me. If you have one let me know ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks!
OD
![switchpanel3.jpg switchpanel3.jpg](https://www.steelsoldiers.com/data/attachments/412/412030-7ee94fd01291d45493388501c0ec88f5.jpg)
Thanks!
OD
