Overdrive
- 96
- 28
- Wentzville, Missouri
Have not installed it yet or ran wiring but wanted to share a pic of my custom switch pod for the LMTV.
The case is the standard LMTV switch box that comes with switch holes. I found out quickly that the standard switch holes are too big for the fun 12v switches you can buy everywhere online so I had some spare aluminum sheeting lying around so I fabricated a new cover plate to fit the switches and added a trans temp gauge hole. Will be working on the wiring soon.... lots of projects!
Pic of the panel on the test bench
will add pics after final install. I have it mounted in the box and in the truck but need to run all the wiring.
As you can see in the pic I am missing the plastic cover for my hand throttle... not sure why but it is bugging the heck out of me. If you have one let me know
Thanks!
OD
Thanks!
OD
