Plane Fast
- 3
- 18
- Panama city FL
Are those LMTV or Humvee seats?
No they are HEMTT seats.
Ugh. That darn tapatalk. Cannot "open file" after it makes me download just for trying to view, on Galaxy S5.Brought home 7 ton's of rock for the re-work of the dog pens. Pulled the pens and mats in a couple previous days. This was 1 days progress.![]()
I hear alot of folks saying that, but I'm using tap a talk on a galaxy s5 with no problems. I see all the pics unless I don't have enough service.Ugh. That darn tapatalk. Cannot "open file" after it makes me download just for trying to view, on Galaxy S5.
Ohh, I see now. I can't load pics to the full site on my phone to though.Yes, but only if you use tapatalk. I like the layout of the full site.
I'd start with the wiring diagram and a meter at the turn signal switch. Lots of possibilities.The blinkers on my m923 stop working, I checked every bulb and looks ok, but blinkers still not working.
Any adea?
Mine did the same thing and it turned out that it was just a bad ground. I personally would check the ground at the flasher relay first (the little black box under the dash by the steering column with only 3 wires coming from it). When I had that issues I was using the stock ground point with the mounting bolt for the relay and it wasn't making good contact. As soon as I moved it to another grounding point it worked like normal. I used the mounting bolt for the warning box and it works perfectly and the ground wire will reach.The blinkers on my m923 stop working, I checked every bulb and looks ok, but blinkers still not working.
Any adea?
Wierd. Crazy electronics!Ohh, I see now. I can't load pics to the full site on my phone to though.
Went to Home Depot to get some mulch.
5 people came over to ask question about this truck,
it's fun to drive around.
Two gallons of gas for power washing is a fair amount isn't it:I came home to a sunny warm morning and got the ole pressure washer out and got the crud off all of them. Only took 2 gallons of gas.
