bikeman
- 502
- Ft. Bragg, NC
Are you coming to the show or just trying to sell your engine?Hi I have it
we are going to try and keep them close together. please post here some examples of what your bringing with prices so people know what to expect. thanks.
Is there a designated area for vendors or just spread out?
New? Used? Price?I have 2 starters for the 8.3 if anyone is on the market for one or both...
I'll take 2 20mm cans.Here are some of things I'm planning on bringing to the rally. If you would like an item please PM me so that your request does not get overlooked and to reduce the number of unneeded posts. Prices are for each item unless otherwise stated. If there is anything that I have listed in the Classified Section that you would be interested in I can bring those with me also. I will be bringing all the CUCV and 6.2L maintenance parts I have listed along with others I just picked up. Thank you!
Warn 18k lbs electric winch with controller but no cable for the spool. $650
Mile Marker 10.5K lbs Hydraulic winch with mount for a HMMWV, Controller, and book. Never used, the only thing missing is the military cable from the winch to the controller $850
View attachment 612233View attachment 612234View attachment 612235
M35A3 Inner Wheel Bearings NSN 3110-01-399-1253 x4 $50
M35A3 Outer Wheel Bearings CTIS NSN 3110-00-399-1251 x3 $50
M35A3 CTIS Brake Valve NSN 2530-01-419-6303 x3 $20
M146 Window $120
Trailer Wheel Cylinder M146, M118, M119, M373, M270, M345 NSN 2530-00-776-0966 x6 $50
900 Series Tie Rod End Set (1LH 1RH) x 2 $75 a set
AMMO CANS - I will be bringing a limited number of these so let me know what you want so I can make sure to bring it!
40mm (18 1/2"L x 6"W x 10" H) - $15.00
20mm (18 1/2"L x 8"W x 14 1/2"H) - $20.00 (Swiss x3)
60mm (15"L x 6"W x 19"H) - $14.00
81mm tall (14"L x 5 1/2"W x 29"H) - $15.00
81mm Brown (25"L x 13 1/2"W x 8"H) - $15.00 (73m819 x3) (Coffey1 x 1) (Swiss x 1)
120mm tall (12"L x 6"W x 31 1/2"H) - $17.00
Pictures show a 50 cal can in front for reference. Next is 40mm, 20mm, 60mm (on right), 81mm tall (on left), and 120mm. These cans all have good seals and most look like one time use only.
View attachment 612236View attachment 612237
This is the 81mm brown box with a 50 cal can for reference, 3 50's would fit inside on of these if you pulled out the foam pieces. They do not have seals. Also they have vent holes on the front and back and the latches are designed to be locked with wire. Any questions please ask.
View attachment 612238View attachment 612239View attachment 612240View attachment 612241View attachment 612242View attachment 612243
