Official 2016 NC Denton Farm Park BUY/SELL/TRADE Thread.......
Ford Mechanic
Edenton, NC
I have a lifting sling, looks to be stainless cable? In good shape, 7 ft long, no frays. SOLD for all 4 at the rally. SOLD!
Beretta92fs
Clayton, NC
Does anyone coming to Denton have a complete front bracket set up for a/c on the 6.2 motors?
My CUCV is still 24V, I plan to keep it that way, and want to add a/c soon but still keep the military set up for appearance reasons.
Al Harvey
19
Dover, TN
Here are some of things I'm planning on bringing to the rally. If you would like an item please PM me so that your request does not get overlooked and to reduce the number of unneeded posts. Prices are for each item unless otherwise stated. If there is anything that I have listed in the Classified Section that you would be interested in I can bring those with me also. I will be bringing all the CUCV and 6.2L maintenance parts I have listed along with others I just picked up. Thank you!
Warn 18k lbs electric winch with controller but no cable for the spool. $650 Spoken For by Landbarger
Mile Marker 10.5K lbs Hydraulic winch with mount for a HMMWV, Controller, and book. Never used, the only thing missing is the military cable from the winch to the controller $850
M35A3 Inner Wheel Bearings NSN 3110-01-399-1253 x4 $50
M35A3 Outer Wheel Bearings CTIS NSN 3110-00-399-1251 x3 $50
M35A3 CTIS Brake Valve NSN 2530-01-419-6303 x3 $20
M146 Window $120
Trailer Wheel Cylinder M146, M118, M119, M373, M270, M345 NSN 2530-00-776-0966 x6 $50
900 Series Tie Rod End Set (1LH 1RH) x 2 $75 a set
AMMO CANS - I will be bringing a limited number of these so let me know what you want so I can make sure to bring it!
40mm (18 1/2"L x 6"W x 10" H) - $15.00
20mm (18 1/2"L x 8"W x 14 1/2"H) - $20.00 (2x Andyrv6av8r)
60mm (15"L x 6"W x 19"H) - $14.00
81mm tall (14"L x 5 1/2"W x 29"H) - $15.00
81mm Brown (25"L x 13 1/2"W x 8"H) - $15.00
120mm tall (12"L x 6"W x 31 1/2"H) - $17.00
Pictures show a 50 cal can in front for reference. Next is 40mm, 20mm, 60mm (on right), 81mm tall (on left), and 120mm. These cans all have good seals and most look like one time use only.
This is the 81mm brown box with a 50 cal can for reference, 3 50's would fit inside on of these if you pulled out the foam pieces. They do not have seals. Also they have vent holes on the front and back and the latches are designed to be locked with wire. Any questions please ask.
Andyrv6av8r
457
Spartanburg,SC
View attachment 612233View attachment 612234View attachment 612235
M146 Window $120
20mm (18 1/2"L x 8"W x 14 1/2"H) - $20.00 (Swiss x3)
81mm Brown (25"L x 13 1/2"W x 8"H) - $15.00 (73m819 x3) (Coffey1 x 1) (Swiss x 1)
View attachment 612236View attachment 612237
View attachment 612238View attachment 612239View attachment 612240View attachment 612241View attachment 612242View attachment 612243
I'll take 2 20mm cans.
Al Harvey
19
Dover, TN
I'm looking for a couple pieces for my M1008. I need the tie down brackets that run along the top of the bed that the canvas top attaches too.
AMGeneral
116
Connelly Springs, NC
Update to my previous post,
I will be bringing the M54A1C for sale and not the Gama Goat,as I already sold it.
I also have 16 Gama Goat wheels with tires,4 or 5 have 50% or better tread with no weather checking,the others just hold air and I would not recommend for road use, $400 for all 16.
