hawkeyepoole
- 2
- 0
- Keller, TX
Jackalope? I got the limit this year just west of Keller Texas. I should post pictures of my biggest at 6lbs with a 10 point rack.
Mounting a Jackalope?Yeah I know of a relative who had one mounted, plus I've seen one on the Internet...
Did you rotate according to the TM, or did you just mix them up?Fixed the contacts in my turn signal, rotated tires, took troop seats out.
That reminds me, I need to figure out what's wrong with my turn signals on my m35. I suspect its just a bad blink box, but I need to do more trouble shooting first.Fixed the contacts in my turn signal, rotated tires, took troop seats out.
Mine is doing the same thing right now. The turn signal switch itself burned up on the inside, I replaced that, now it just doesn't blink. I found some exposed wires near the blink box so I'm thinking that's what caused the switch to burn up and possibly shorted out the blink box. I took the box off, hooked straight to the battery, negative to the old ground, positive to the B terminal, and all I got was a solid light out the A terminal.That reminds me, I need to figure out what's wrong with my turn signals on my m35. I suspect its just a bad blink box, but I need to do more trouble shooting first.
When you select a blinker, the green light comes on solid on the switch, and none of the lights activate outside the truck.
On the contrary; it IS special, in fact it's ingenious!
After I go over my wiring, I'm going to swap the known-working box out of my M109 and see if that doesn't fix it.Mine is doing the same thing right now. The turn signal switch itself burned up on the inside, I replaced that, now it just doesn't blink. I found some exposed wires near the blink box so I'm thinking that's what caused the switch to burn up and possibly shorted out the blink box. I took the box off, hooked straight to the battery, negative to the old ground, positive to the B terminal, and all I got was a solid light out the A terminal.
I've seen those before:I drove mine today. First time in about 3 months. Dropped it off at my tire place to have them look at one of the tires that keeps loosing air.
On a side note, does anyone know what this is for? It is mounted to the dash.
I think that's a tampon dispenser; takes quarters only.You have expensive taste, and a very nice bathroom to boot.
I was actually talking about the grey thing.
Got to check the TM.Isn't there a rule against something like that in a truck this size?
