Another Ahab
- 4,903
- Alexandria, VA
Yeah, 60+30 is indeed only 90, but if Gadget also decides to add the Lucas Super Coolant stuff he mentioned, there has to be some room left for it, right?I hope you are filling that last 10%. Unless my math serves me wrong 60+30=90![]()
I'm sorry to hear about your lesson; that sure doesn't sound like fun at all.Warning BEFORE you stick your hand in though a mess of rat dinner wiring, TURN the master switch OFF, due to me NOT heeding my own warning, I am about 20 gal. of blood short, along with a sore/cut elbow, sour/cut wrist, and a cut on the top of my bald head (to brain dead to be sore).
I really like this guy. No matter how bad the problem is, dive in head first and get er done. Ron, thank you for the update and for the tipsWell the POS truck starts with the start button, no clutch button, trying to get the turn signals working, I see NO need for turn signal fuses, or for that matter any fuses in the lighting system, most of the older military trucks (939 and down) do not have them, not worrying about water proofing, the rest of the system is far from water proof. I guess just pick something not working and get it working, then go no to the next rat dinner, speaking of dinner, I found the REST of the defroster tube, ALL 18" of it.
I also found that after the master switch and the on/off switch is turned off that somewhere in the system something is storing juice (sorta like a capacitor), it takes about 30 sec.for a relay to open (you can here the "click", then no more juice, so be careful.
Congratulations! Now you can start (no pun intended) using the screwdriver for other things.Well the POS truck starts with the start button...
... I am about 20 gal. of blood short...
And being 20 gal. short will definitely give you nice and low blood pressure. Which can be helpful when working on certain vehicles.
What? No photos?Congratulations! Now you can start (no pun intended) using the screwdriver for other things.
All I got done today was reinstalling the formerly bent axle locating rods.
What? Of straight rods?What? No photos?
I'd remove the plug a seal carefully, then stick them back in.I will be draining the coolant the manual states to drain from engine block by removing plug and seal ring, it states to discard seal ring and intall plug and new seal ring, does anyone know where to get new seal ring for engine block? Appreciate your replies.
Looks just like your straight ones, except that mine are now painted (largely) flat black, so they're hard to see. Until I lay that one on its side, that is.
Alright, you got me curious. Why would you want to be at the upper limit?For the 24 Quart system, that leaves 14.4 Quarts of antifreeze, and 9.6 Quarts of Water. That's approaching the limits of what the experts recommend, right where I'd like to have it.
There should be a government backed study, "what attracts rodents to the FLU419?", like opposed to the AMC GremlinAlright, you got me curious. Why would you want to be at the upper limit?
I always try to stay at the lower limit, enjoying the increased heat transfer and money savings that result from using as little anti freeze as possible.
And speaking of anti freeze, I captured some in a bucket when the freeze plug on the M1009 let go. Then put some of it to good use.
No rats in the SEE, but mouse droppings have started to appear in the cab. Thinking that the little critter(s) might be thirsty, I put a small bowl of anti freeze on the floor.
Gotta check today if it needs to be refilled. It has rained a fair amount recently, so they can't be all that thirsty.
Without resorting to using tax dollars, I happen to know what attracted rodents to mid 2000s GM pickups.There should be a government backed study, "what attracts rodents to the FLU419?", like opposed to the AMC Gremlin
There you go. It all makes sense now:Without resorting to using tax dollars, I happen to know what attracted rodents to mid 2000s GM pickups.
For whatever reason, GM thought it'd be a good idea to lube up the wiring harnesses with (basically) peanut butter.
As far as them liking the SEE goes, maybe it's like people often preferring exotic food? Not that German food is all that great.
Hot doggity! That's probably what happened.There you go. It all makes sense now:
- in Germany, Daimler-Benz probably lubed their harnesses with sausage fats.![]()
