Installed a HMMWV dual voltage output alternator. 100A on the 24V side, 25A on the 12 (I think).
What a pain in the you know where. Oh lordy.
I got this alternator from Maccus a while back. My stock 60A unit died and this was the only spare I had, so I had to go ahead and install it.
First, I had to bore out a deuce pulley and then have it shortened-long story, but someone sold me a pulley that wasn't deuce (don't know what it was) and I didn't notice it wasn't correct until I'd spent $80 at a machine shop having it bored. So I had it shortened and used it. Oh well.
I bought 15' of 4G welding cable and soldered lugs to it on both ends. I had already rebuilt my battery box last year with civvy batteries with an eye towards this eventual job, so the batteries were already offset to one end. I found an 81R battery that fir perfectly (correct height) for the alternator to feed.
Man, this alternator is heavy and fun to install. Since it was out, I went ahead and replaced the lower radiator hose.
I had to make a little jumper wire from my factory harness field wire-the factory 60A alternator field wire has a packard and this alternator uses a ring terminal, so I made a short wire to plug in so I wouldn't have to modify my factory wiring harness.
After doing all this, my recommendation to anyone who needs a lot of 12V power would be to just suck it up and buy an expensive high output converter. Much easier.
Battery box mod:
![20160903_184038.jpg 20160903_184038.jpg](https://www.steelsoldiers.com/data/attachments/441/441082-2849a6d33e5af9c02827ce13040f5c38.jpg)
![20160905_190944.jpg 20160905_190944.jpg](https://www.steelsoldiers.com/data/attachments/441/441090-6cac1e475c875a3cbffc485e5f3b48c4.jpg)
![20160905_190939.jpg 20160905_190939.jpg](https://www.steelsoldiers.com/data/attachments/441/441089-1ed77c55ac78efdda23c699c14ba0661.jpg)
![20160904_104803.jpg 20160904_104803.jpg](https://www.steelsoldiers.com/data/attachments/441/441088-249c4901ce298d828b127e53e387e474.jpg)
![20160903_192958.jpg 20160903_192958.jpg](https://www.steelsoldiers.com/data/attachments/441/441087-69be2a8a9b5b3c7ab70e031fddebd56e.jpg)
![20160903_185922.jpg 20160903_185922.jpg](https://www.steelsoldiers.com/data/attachments/441/441086-e46197a6d67c8d31b28205b46f79dfd0.jpg)
![20160903_185917.jpg 20160903_185917.jpg](https://www.steelsoldiers.com/data/attachments/441/441085-5caaf74cc43cfb7013cd1ea3814f0dba.jpg)
![20160903_184043.jpg 20160903_184043.jpg](https://www.steelsoldiers.com/data/attachments/441/441084-21a0bd7b700be61934ca2921e077e056.jpg)
![20160903_184041.jpg 20160903_184041.jpg](https://www.steelsoldiers.com/data/attachments/441/441083-f00b6be9dd1909460ff73b976e29477f.jpg)
Why yes, that other switch does say "rear winch disconnect".
Alternator:
![20160916_110759.jpg 20160916_110759.jpg](https://www.steelsoldiers.com/data/attachments/441/441099-e6f51767ff07dee2c61e5d91fbff262b.jpg)
![20160916_110748.jpg 20160916_110748.jpg](https://www.steelsoldiers.com/data/attachments/441/441098-6c4c9d9da06014dfaf8d17ec9de449f8.jpg)
![20160916_110746.jpg 20160916_110746.jpg](https://www.steelsoldiers.com/data/attachments/441/441097-ea074e4712cacae926a2b411e9edd4d8.jpg)
![20160916_110743.jpg 20160916_110743.jpg](https://www.steelsoldiers.com/data/attachments/441/441096-9f42e6541e27de9baa0c2079b5d9041e.jpg)
![20160916_110728.jpg 20160916_110728.jpg](https://www.steelsoldiers.com/data/attachments/441/441095-05edeac1f74c3b9626d9b24de4e813d8.jpg)
![20160916_110705.jpg 20160916_110705.jpg](https://www.steelsoldiers.com/data/attachments/441/441094-f9024c80341762c2ef51f141263fbb68.jpg)
![20160916_110656.jpg 20160916_110656.jpg](https://www.steelsoldiers.com/data/attachments/441/441093-8adf0fede75c26b6905cf396c9c788b1.jpg)
![20160916_110641.jpg 20160916_110641.jpg](https://www.steelsoldiers.com/data/attachments/441/441092-dd50b6db7694725a33c04db8a5f31d63.jpg)
![20160916_110801.jpg 20160916_110801.jpg](https://www.steelsoldiers.com/data/attachments/441/441100-0a5e8de3ff343d461c45452c00419fc7.jpg)
