10 kw generator mep 803a
Guyfang
27,256
Burgkunstadt, Germany
You guys are spot on! Before you start any job, clean it up. Also keeps dirt and junk from being introduced into the fuel system. keeps you clean, and the laundry lady happy also!
CT-Mike
CT
LindyP38,
Sorry to get OT but what is your connection to Eagle Point? I was born in Medford, and my parents moved to Eagle Point when they retired.
liebsce
Ashland, Va
Does anyone know the part number for the mating connector of the diagnostic port? I am assuming it is a mil spec. amphenol part but cannot seem to find it listed anywhere. Thanks.
m-35tom
226
eldersburg maryland
you need to download 'Amphenol /Matrix MS/Standard MIL-DTL-5015 Cylindrical Connectors'
from there you can use the info from your connector to find the mate. be prepared for it to be VERY expensive.
Guyfang
27,256
Sadly, the military paid for a wonderful diagnostic system, compatible to all MEP-8XX gen sets. Just think, one test set to use on all generators. Then was too cheap to pay for the hardware and software. So naturally, they never put the canon plug in the parts manual.
Gives me the chance to complain about not having the FEDLOG files. If you look up the male side of the plug in FEDLOG, it gives you the female side NSN.
liebsce
Ashland, Va
Using info provided by m-35tom I was able to find the insert and proper pin arrangement. My 803 is a 2010 model and it appears the connector was changed from screw thread to bayonet somewhere along the line. I'm not giving up yet. Looking at the wiring diagram I believe it is possible to build a display for this unit.
sandmanxx
San Antonio/Tx
Question on the fuse mod..
My MEP-803A has the fuse mod. But the main stator is blown - 1.2 ohms. That's direct from cutting the pin connector leads and stripping the wires.
SIDE NOTE: Try messing around with these and your truck with a blown knee on crutches. I really want to get the MEP-803 going but it's almost impossible
to move the engine around, work on floor, reach across for whatever, maneuver in a 2 car garage with enough stuff to fill a 4 car garage lol..
Not a happy camper here.
DieselAddict
2,354
Efland, NC
Can you post your test results?
zarathustra
60
glasgow,ky
Y'know if one looks at the diagnostic port he'll see that very few pins are used. It wouldn't take much to swap out that large connector for something smaller that has both the Jack and Plug side. Done well, it could look pretty spiffy.
A wheatstone bridge is used to measure resistance (especially in low resistance) circuits very accurately. I'd hazard a guess that if one used a good quality ohmmeter he could get a good (enough) go - no go reading. Probably best to use an analog ohmmeter rather than digital in order to see the fine values rather than the averages, rounded to whatever the digital ohmmeter specs are. Just remember, when reading resistance one must make sure that the component is isolated from all other components, or there may be some "back current circuitry" affecting the readings.
When measuring the stator, be sure to measure resistance between windings to check for shorts between windings. That inter-winding resistance should be infinity
If you really want a wheatstone bridge, they are for sale on ebay.....
m32825
173
Central Florida
So an update as promised I did indeed obtain the special switch thanks to
zarathustra and his great lead on this part.
So I did contact
Quantum Controls
Chanhassen , MN
1-952-361-3694
and asked for Wendy
The part number for
S14 switch in the mep-803a is part # SDS1008821091 switch.
Here are some photos of the relay and what it looks like in case anybody needs to know.
SO did indeed pay the 75 dollars pretty cheap considering how easy it was to get the part in my opinion.
Thanks for posting this. Updates...
When you call ask for Brenda. The part number is SPS1008821091 (not SDS). The cost is now $78 plus shipping.
-- Carl
mijoe
Tallahassee, FL
Hey there, did you ever find a connector that fit your rig and a pinout to go with it? I am in the process of figuring out if I can build a diagnostic display for my rig too.
