- 75
- 0
- 6
- stratford/CT
Hi there I purchased 4 like new 95% 37" goodyear's about a year ago I have put about 5k on them (mostly street) and there 1/2 to 3/4 worn already has anyone else had this issue with surplus tires?
That's weird I have the opposite wear on my duallsThe outside tire on all of my dually trucks wear faster than the inside tire.
Yep, should be shortly after the letters DOT. Only 3 digits if there older than 2000 (then you have to guess on the decade) Also, 20psi seems awful low?Date of manufacture of the tire will be near the rim inside an oval. If they are made after 2000, they will be a 4 digit code that is something like "1509", which translates to week 15 of 2009. 3 of mine are on the outside and easy to see (I checked them last night), I suspect the 4th is on the other side of the tire or something.
