- 75
- 0
- 6
- stratford/CT
Oh good to know I'll check it out but mine definitely says TP20 over the wheels
Sorry, I forgot how big those tires were...20 psi is painted right over each wheel
If you had one tire slip, then the power goes to that tire, the path of least resistance. You can juck up one corner in your driveway, put in D and throttle up. It won't move. Learning how to drive these properly may have helped you in the mud. research "BTM"I have been running mine at 25psi and I also removed the rear camber shims since the heaviest thing I will haul is probably a bag of groceries. So far it seems fine. My biggest gripe is the tires themselves. They are pathetic in mud, I got stuck in about 8 inches of mud an of course the old 6.2 sounds like its cranking about 10,000 rpm but the tires are turning at what appears to be 1 rpm-they just can't self clean the thick heavy clay type mud. I was pulled out with an ATV-now that's embarrassing. Driving it on snowy, slushy roads is not pleasant or impressive either.
I apologize for my ignorance. Please explain how I should have driven it properly. I'll explain the terrain so you can give me the correct procedure.If you had one tire slip, then the power goes to that tire, the path of least resistance. You can juck up one corner in your driveway, put in D and throttle up. It won't move. Learning how to drive these properly may have helped you in the mud. research "BTM"
Why do you go by what's painted over the fender ???20 psi is painted right over each wheel
He's referring to a method of utilizing the type of differential in the hmmwv. When a tire loses traction you use the brakes to stop the wheel from spinning thus sending power to the wheel with traction. Do some research on how to properly do this as damage could occur to drive components if done improperly.I apologize for my ignorance. Please explain how I should have driven it properly. I'll explain the terrain so you can give me the correct procedure.
1. Path is about 30' wide with brush/tag alders on the left and a barb wire fence on the right-Humvee is in the center.
2. Its pastured low/swamp land so the ground is rough from holes punched in the ground from the cattle.
3. Ground is flat an comprised of thick, heavy, sticky type of clay. The type that sucks your boots off your feet when you walk through it and stays on your boots making you walk like you have a cement block on each foot.
Hope that helps explain the terrain, if you need more details let me know. Otherwise- there you are facing that obstacle for the next 50 yards or so-how do you do drive through it properly?
