dstang97
- 33
- 48
- Clover, SC
Why is there 2 pumps that feed the filters? Do they both pump at the same time? Is there 2 in case one breaks?
one of them is very loud but not pumping and fuel/water/sludge.Are they making ANY noise, dstang97?
The best way is to take the pump off and clean it. The only bad thing about the 002/003 IP's is they have a plunger guide, which is a thin piece of metal and when the plunger gets stuck, it binds, breaking the guide. Then you have to take the pump apart to get the guide out and replaced.Is there a write up on how to clean the plunger on an injection pump? Mine is getting fuel to the IP and then stops.
Just got the unit. The fuel system was horrible it sat for years. Flushed he fuel system all new filters and tried running it off a Jerry can. The injection pump is not pumping the fueldstang97,
Give us some backround. Have you seen this generator set run before? Or are you trying to get one running that has been standing for ever? The guide Jamawieb is talking about, tends to break when the set has not run for forty forevers. If it been in running condition, of late, that may not be the case.
The above passage was gold worth. Oops, that was german, translated into english means, its worth its weight in gold! You know, maybe what we should do is set down and write a check ölist people should use when buying a gen set. Because there are certain things that happen over and over again. Might save some time and money for some unlucky person in the future.The plunger is inside the injector pump. In simple terms, it gets pushed by the cam shaft and drives in/out delivering fuel to the injectors.
Inside the pump are very tight tolerances and the smallest amount of varnish will make the plungers stick. In the center of the pump, in between the injector lines, you see the big 7/8 (I believe) cap? If you take that off, you have a 16mm threaded type bolt, after you remove that, be very careful because their is a spring and delivery valve inside. When you take all that out, you will see the top of the plunger and you should see it move in / out while you rotate the motor by hand. If it doesn't move as you rotate the motor, the plunger is stuck and if you're lucky, you can spray carb cleaner inside and lightly hit the plunger with a brass punch. Then rotate the motor and do it again. Hopefully the plunger guide did not break but you won't really know until you see the plunger moving and the motor will NOT start.
Usually, what I do with a generator that has been sitting for years is to fill the last fuel filter with lacquer thinner, then turn on the fuel pumps and rotate the engine over by hand, while moving the throttle linkage. The lacquer thinner with mix with the fresh diesel I put in the tank and will dissolve the varnish quickly. But you have to do it fast because the lacquer thinner will get diluted to much after a long period of time.
Needle nose. It will be the delivery valve and a holder. The top of the plunger is flat, with a hole in the center.Just looked again at the manuals. Looks like I was tapping the delivery valve. How do you get that out?
