gottaluvit
Sprayed saltwater all up under it! That is the bad part. Good part is it ran like a champ on a 250 mile round trip pulling an M1082 trailer loaded on the return with 3700 lbs and snow covered roads. Had to lock in the front differential coming up from the valley close to my house on an unpaved road. It had a couple inches of snow and a 100' drop off with no guard rail. Thought it best to not wait til it was too late to lock it in.
big block 88
17
Topeka/Kansas
Plugged the block heater back in for the nasty cold coming again. I see there is coolant leaking from somewhere by the oil cooler. I see a small pool of coolant on the ground under the truck also in the same area.
Anyone have any idea what it might be? Its too **** cold to go try and hunt down the leak.
M35A2-AZ
392
Tonopah, AZ
I would check your hose clamps.
big block 88
17
Topeka/Kansas
Hose clamp is what im hoping for. All i felt like doing in the cold was grabbing it and checking the hose for tightness. It "seemed" tight. Supposed to warm up in the next week i should be able to get out and check it out.
Its been exposed to - temps several times this year im hoping the oil cooler didnt crack or somthing a long those lines.
simp5782
Feo, Fuerte y Formal
9,383
Mason, TN
Have parts in stock sir!
Sent from my SM-G860P using Tapatalk
big block 88
17
Topeka/Kansas
If i can ever move all my **** deuce parts i will get the barn cleaned up again and start piling parts for the 5 tons. Issue this year was we got our 925 running and a friends 923 running so the few parts i had have been exhausted.
Swamp Donkey
The Engineer
120
Gray, GA
Got tired of changing heater blower motors, this is the 4th ruined motor between 2 trucks. Used a mrap vent fan, will do a write up when I get to building the 2nd motor. 2nd photo is a comparison between old and new motor sizes
View attachment 661205View attachment 661204
I'd appreciate a write-up. My surplus guy has one that I planned on picking up for the same purpose. The data plate showed it pulls 28A though. If it creates much better heat and volume I'll give it a shot.
therooster2001
44
Colorado
Might also be the petcock down there.
155mm
Chief and Indian
389
Guymon, OK
you are correct on 28 amps, the heater CB is 30 amps, so just squeaked under. I only run mine on low, high speed sounds like its going to eat through the fire wall, but this is also the first run, so there will be upgrades.
